- May 26, 2013
- 90
So, after watching Lazze, spot welding some Aluminium sheet together using a spot welder, and some mild steel stock separating the copper electrodes from the Aluminium, https://www.youtube.com/watch?v=gcgC3V3mkcw I thought I'd give it a try as well!
I welded two pieces of 1.6 mm. 5005 Aluminium together, whilst using 2 pieces of 0.55 316 Stainless Steel to keep the separation. Worked a treat!
I tried differing pressures, as well as spot timing, and was quite impressed, but NOT as impressed as I was when I tried to separate the Aluminium coupons, tore the Aluminium right off the welds, these welds are keepers!
My question is, WHY does Aluminium behave differently under the spot welder when I use the Stainless Steel strips? Can I simply turn up some Stainless Steel electrodes, and place those in my welder instead?
Anyone...?
Anyone...?
