- Jan 23, 2017
- 2
I learned on a chef's forum that a smooth steel knife hone is better for knife edges than a ridged one.
I purchased a 3-foot length of generic annealed, water-hardening 7/16" diameter tool steel drill rod at my local metal yard, cut an 8" length, cleaned up the ends on the disk sander and chucked it in the drill press and smoothed the rod face using up to 2000 grit wet-or-dry paper and then metal polish. This gave a mirror finish that aligns the edges of my kitchen knives beautifully. I mounted it in a hardwood handle. Since it has not been hardened, it is scratching more and more with each use. It seems to be becoming more like a store-bought ridged steel hone with each use.
I would like advice on how best to harden it and whether or not it really needs or would benefit from any subsequent tempering.
I've had some success working with very small diameter drill rod. I made some bark grafting knives that I use to flatten the round face of an accepting branch so that it matches the flat face of the scion. They are simple j-shapes made by bending broken 1/8" long drill shanks back on themselves after flattening and shaping a chisel cutting edge at the end. These I made by annealing the rod, shaping it, quenching the red hot rod in old motor oil, polishing it, and then carefully drawing the temper by chasing the peacock colors from the shank end towards the cutting edge and then quenching.
I'm concerned that I have more to learn before I work with something as heavy as 7/16" rod.
thanks,
baumgrenze
thanks,
baumgrenze
