Slitting Saws and Arbors
65arboc
Apr 25, 2014
32
So I think I need a slitting saw for my ShopTask 17-20 XMTC Gold Series bench-top mill. What should I get to get started? I mostly cut aluminum but may want to slot some mild steel parts. I see MSC has a bazillion choices but where to start?:thinking:
Thanks,
Jim
I don' t know how much this helps, but I'd suspect your machine lacks the rigidity to use thicker saws (but I could be talking out of my hat and apologize if so.) I mostly use mine to slot 4130 tubes for dropouts in bicycle building and I can turn .25" saws for one cut or thinner ones like .035" doing two cuts for this sort of thing.
The thinner blades are obviously easier to use with a less-rigid setup as the thicker sort will bounce a bit while cutting. You also need to know how deep you're planning to go. The arbor is going to take up a good chunk of depth.
Pay attention to feeds/speeds so you don't burn up your saw. They need to run more slowly than something smaller like an endmill or drill.
You might want to take a stroll through ebay if you don't have a need for a specific size. Seems like plenty of them out there. Most of the ones I bought were still sharp and ready to work, and tons cheaper than MSC. I'd also suggest a decent arbor like the sort that are MT2 or R8 (or whatever you need) as opposed to the one in the photos. It does handle multiple blade sizes and has a .5" shank, but it can slip and the fixing screw is normally difficult to remove even though I kept it clean and oiled. I seem to recall stripping a couple of cheap allen wrenches trying to loosen it once before.
-Ryan
8454209357_daec479c4c_k.jpg 6663818775_4e95496e83_o.jpg 8564310564_fb62d44db7_k.jpg
I have a Grizzly R8 arbor a d a few of their HSS blades. Very nice stuff for the money...
Ryan pretty much covered it. I buy a lot of cutting tools, including slitting saws, from Victor Machinery. They a good selection at a reasonable price.
Tom S
Martindale has a very good paper on saws. It has a lot of info.
A good exaple is page 13 on cutting speeds and feeds.
