- Dec 22, 2015
- 561
I've been looking at some slitting saws for the Milling machine and the closest supplier lists them for cutting thin wall tubing, so I thought that was all they were good for but I found a couple of videos showing people using them to make deep cuts in mild steel. The cuts were in material that appeared to be about 1" thick and the cuts looked to be about 1" deep. Are the there different slitting saws made specifically for cutting thicker material or will the cheap chinese saws work? If so, does it matter if a 36 tooth or 72 tooth saw are used? The ones I am looking at are 2 1/2" to 3" diameter.
I would love to use one of these for some of the cuts I've made so far, instead of dulling my end mills removing large amounts of material.
