I need to be able to make some small shaft couplers out of aluminum. To do so I'd planned to machine a ring out of 6061 1" alu but I need to add a slit to it. I've never used slitting saws and am not sure what to get. I have a small RongFU RF31 mill with limited speeds, and a R8 arbor, and a 6" Kurt vise.
I can determine the thickness (kerf) I need and I figure at my speeds I need to use HSS. But I'm pretty fuzzy on the diameter and number of teeth to choose, and rpm to run. I figure the cut will need to be no more than 1/2" deep.
Also advise on clamping and setup would be appreciated. I figure the way to do it is clamp it so it sticks out of the side of my 6" vice. If there's a more appropriate way, help appreciated.
