I have this smooth (keyless, teeth with no set) slitting saw. It is 3.14 in x 64 thou 100 teeth (80x1.6mm).
My calculations tell me I could run it conservatively at 80rpm (20m/min or 60sfpm) and ~16iom feed (400mm/min) which results in 0.05mm (2 thou) feed per tooth.
I'll be slitting mild steel to a depth of 3mm (in one or two passes).
Now it all sounds great, but I once long time ago broke a slitting saw when it slipped on the horizontal milling arbor (being keyless) and the table feed crushed it :-( I still keep the broken bits with my good slitting saws to reaming myself yo triple check when running them.
So, anyone that uses those hss slitting saws (with straight teeth) successfully, please let me know if this makes sense or should I change anything?
