I see many thicknesses of slitting Saw available. Would it be safe to run a narrow gauge in multiple passes to make a wider slot? Example 1/32 on 2 passes to make a 1/16 slot.
Interesting question for sure. I would think that part of the answer would require to know how deep the slot will be. I would think a large diameter deep slot my cause the cutter to deflect.
I use jewelers slitting saws of various widths and I stack them to get the correct slot width on the first pass.
