While the size I have worked with is much smaller, it may well be similar tubing. I worked in a steel mill where water was sprayed on the hot steel as it moved down the casting machine. (continuous caster) The instruments I worked with were fitted with 1/4 to 1/2 instrument tubing. As a speculation, the water lines "appeared" to be the same material. Some up to 1-1/2 OD. The tubing was stainless steel, I don't know what grade. But it was mildly magnetic. With the measuring equipment, some was fluids, some gasses. We used water, hydraulic oil, lubrication, and some others. Then there were the gasses, air, nitrogen, natural gas, and a couple more. The mill was dirty, plain and simple. The stainless tubing made an appreciable difference in that dust and dirt. That's my take on it. . .
