Sliding Tailstock Drill Chuck?
raross61
Jun 28, 2013
137
Just wondering if anyone had a good design for one of these? Mine is a mt-2 in the tailstock.Thanks
I realize this is an old thread. Did you ever build a tailstock drill chuck? There was a nice design for one in HSM a couple of years back. I actually want to build one for my 2MT as well. If you want it I can get back to you with the proper issue info.
Al
Al
Yes I would be very interested in the one in the HSM if you can find it. Thanks Bob
Hi, Bob.
Sorry it took so long to get back to you. The article is in HSM May/June 2014. Back issues should still be available. Looks like a fairly simple design. It uses Morse Taper extension in the tailstock which you bore out and put in a piece of drill rod. The MT extensions can be bought for $10 or less. The only problem is that it was designed for 3MT and my lathe has a 2MT. I'll give it a try it and see if it has enough "meat" to work. If not I'll go to an outside design that clamps around the tailstock quill. Hope this helps.
Al
Hi, Bob.
Al
Allan,
Thanks for all your help I will look into this. Bob
