Sleeve Bearings For Craftsman 101.
building2
Mar 15, 2015
8
Does anyone know if sleeve bearings are still available for the Craftsman 6-inch Model 101 headstock spindle pulley? Any help would be appreciated. Thanks in advance.
Which model? There were two sleeve bearing models, 101.07300 and 101.07301 (read the sticky at the top of the forum). As recently as January, Clausing still had the bearings for the 101-07301. I don't know about the 101.07300 but I doubt it.
Thanks for the info. It's a 101.07301 and I did find the bushings at Sears. As a note, Clausing also has them but since I'm located in California they can't sell to me direct. Too bad, they were less money from Clausing. Oh well, at least they are still available.
Yeah, Clausing apparently had a run-in with California's Sales Tax idiots and the ultimate losers were people in CA. They are far from the only company that refuses to sell into CA. If you have a friend in NV or AZ, get them to order them for you. Part number is the same but to avoid confusion, you have to start with the Sears Model Number (some other company probably uses the same part number).
