I used to take it for granted that holes are always perpendicular to the table until I checked a couple of 8mm holes drilled on a 7075 Aluminium block last night. Both were slanted. The way I did it was drilling out the center with a 4mm center drill ( the biggest I have got ) , then a 4mm through hole followed by 6mm and finally 8mm. What I used to believe is that the first hole should guide the drills used in later stages and the final hole should be just as straight but it was not. Is this my misunderstanding or something else caused the problem ? The other two smaller holes I drilled on the same block are all good. ( 4 mm center drill -> 4 mm through hole -> 4.2 mm final hole )
