Sino error
stuarth44
H-M Supporter - Gold Member
Jan 22, 2020
197
sorry to maybe cover old ground, but searching does not answer my query
just put in Sino on the lathe, getting 003 error on the x, have not (setup) yet, mainly cos learning howto, can setup cure this error? what say you?
I have no idea, but I saw this. Others I saw were too fine of resolution, and being in metric.
Did you setup Sino scales with TouchDRO, or did you set up SIno DRO? If TouchDRO, you need to calibrate it as described on the DRO Scale Calibration. If you are using Sino DRO - I don't know (and this is probably not the right place to find out unless someone used Sono before).
Thank you
Yuriy
Thank you
Yuriy
thanks, no, i did none of that, I'll have a shot in my morning and hey appreciate your help, you see, the crowd that sold it knows zilch, I am east coast, I had to call a seller 3000 miles away on west coast, but you've givien me a starting place ycroosh
not very good at making videos I'm afraid
