Single point threading - What size to turn to?
Christianstark
H-M Lifetime Diamond Member
Nov 23, 2020
820
Need to cut M16 x 2 threads, and the first several I had to cut well beyond a triangle thread to get it to fit a M16 nut.
Where can I find what dimensionsI should be starting at for imperial and metric threads on the lathe.
For reference I was starting at 16mm.
Thanks!
Grab a copy of Machinery’s Handbook. A must have for anyone working metal. It’s all in there. usually easy to find on ebay or used from Amazon at reasonable cost.
Very correct. The guide. I have a copy from my father. Relatively easy to pick up a used one at a decent cost.
I always start with the nominal diameter for external threads, and usually do a bit of filing to deburr the peaks of the threads, so the finish diameter ends up being a small amount smaller than nominal size. For ordinary work, we can get overly technical about things, going to Machinery's Handbook can be a rabbit hole, timewise, if the nut or thread gage says that it fits, it is good to go. If I am making a thread plug gage, I go to MH and use the thread mike or wires. If single pointing internal threads, the tap drill diameter will do the job in most instances.
Awesome! Thanks all! I found a rule log thumb online that worked pretty well as well. Major Diameter - 10% of thread pitch.
M16 x 2. = 16mm - (2mm * .1) = 15.8mm
This worked well. great fit on a nut I had for testing.
Most modern threads are to the "Unified Thread" form, even metric. Such a thread is of a "V Sharp" form with rounded off valleys (root) and peaks (OD). Such roundness is ostensibly to allow for tool wear in a production environment. For the "casual" user doing a single point thread on a single use object, this involves cutting a "V Sharp" thread and then smoothing the peaks of the thread form a little. Usually 8-10% of the thread size is sufficient.
Casual machinists will often cut down the OD of the device to make this adjustment. To do so has become a common practice. It is not a true reduction, just a "git by". While it does work, it takes an extra pass (or two) before threading. If the application is not a "spec" job, like an aircraft, threading full size "V Sharp" and touching up with a file or other abrasive will suffice.
Even cutting a M16 OD starting at 15.8mm required some file work on the threads to fit the nylon lock nut I had, and even then it required a wrench just to get it to the nylon. After the first 3-4 turns I could tell it was a tight fit laterally and in and out. No slop. Was threading H13 tool steel
You can find online versions of Machinery Handbook for free. Get a later number like 28 or 29 to make sure you have Metric. It is the bible. I printed out the pages and put in separate notebook that is in shop for Metric and Imperial. I use a number a couple of thousand below the max 3A fit for most of my stuff.
