Single phase to three phase equivalent
Suzuki4evr
Sep 29, 2017
2,307
I want to change my single phase motor on my mill for three phase. What is the 3phase equivalent to a 2HP (1.5KW) single phase or closest to and do you get a VFD or VSD for the 3 phase? I have 220v power supply.
Thanks for the help.
2hp = 2hp You will get full power from a VFD. This is not true for a static phase converter, with a static converter you will only get about 2/3 of the rated power of the motor.
HP is HP, so a 2 HP 3 phase motor would have the same output. The frame size is really what matters, so do whatever you can with that! Additionally, you could use a higher HP motor, which would make lowering the RPM with a VFD 'better', since it would have better torque at lower RPMs.
As others as mentioned Hp is Hp be it single or 3 phase, but what is often missed is that below the motor's base speed (typically 50 or 60 Hz) you loose Hp in a linear fashion and you also loose the mechanical advantage. So if you were to reduce the motor speed to say 30 Hz you loose 50% of the motor Hp, the torque is typically flat below the motor base speed. But you loose the 2:1 mechanical advantage if you maintained the motor's full rated speed and changed the mechanical ratio. This is one reason why VFD motors are often oversized and also driven above their base speed. So on a smaller mill with a factory installed VFD system you often will see a 2-3Hp motor used with 2 or 3 mechanical ratios. On my mill the motor covers 20-200 Hz, and 2 speed ranges of ~ 40-450 and 400-4500, i.e. direct belt drive with a back gear. On a lathe they are also typically have 2 mechanical speeds, on the lathe motor replacements I belt down the motor and run them to ~120 Hz, and recommend a usable speed range of 20-120 Hz.
VFD's are also able to provide higher torque levels over short periods of time (like 150-180% for up to a minute), one reason why the supply amperage/fusing needs to be higher than the motor specifications.
mksj has the important point here. You want to go to a larger motor so you can use the VFD as a speed control - that's the BIG advantage of a VFD.
Like was said, take a look at mounting issues. Don't get one so big its hard to mount.
