With a little experimenting, I find one can run both X and
Y simultaneously on a Monarch 14 C. My question is: Will the machine cut at a 45 degree angle?
Why not dykem the metal and scribe a forty five and find out? In theory you should be able to cut circles , hexses, arcs and any shape you can think of.
It probably won't cut on a 45. The feed rate for cross-feed is half that of the apron feed, since you're reducing the diameter, not the radius. So my guess is it will cut a 63 degree angle. Try it.
