Simple circle cutting apparatus
Tmate
H-M Lifetime Diamond Member
Jul 15, 2020
422
Some 30 years ago, I put together this circle cutting contraption using a magnetic base, a Grainger gearmotor, and a toy train transformer. It worked, but would have been a lot better if I had used heavier parts. Back then, all hobbyists had was acetylene torches. Today, a hand held plasma torch moved around a circular steel template would accomplish pretty much the same thing.
Here's another -- this one was a track cutter. Again, it used a Grainger gearmotor and a toy train transformer. Two wheels in the foreground had V grooves in them so the could ride on an inverted angle iron track.
Very clever. Adapt and overcome!
This is how I've been doing it. Works equally well for small circles or large, there's a slight learning curve to getting nice parallel cuts, but otherwise it's pretty easy.
images
