I have 3 strips of brass to solder/braze to every other side of a hexagonal nut.
The nut is 19mm across flats and the strips are 25mm wide.
The nut must be at 90' to the strips and all three strips must sit flat so there must be no movement during the process.
I am considering using 2 small M3 screws at the end of the strips so they bolt onto the hex getting it all flat and tight then silver soldering the whole assembly.
If I were using soft solder I would pre tin the parts before heating.
Is a similar process possible with silver solder/braze?
Is it even worth while or just rely upon the solder wicking into what would be a tight joint?
