Here are some circuit boards I cut for a friend of mine.
Doubled sided PCB's each board had about 120 holes that differed in size and the pcb needed to be flipped over to
cut the back side traces. I cut them pretty slow. since it was a one off job.
[video=youtube_share;OoeAzXuXpaI]http://youtu.be/OoeAzXuXpaI[/video]
1st mov hole drilling I think each board had about 120 holes.
[video=youtube_share;fgwPuK5165w]http://youtu.be/fgwPuK5165w[/video]
2nd movie scoring the board. for easy separation
[video=youtube_share;2hQz2XGcOZ0]http://youtu.be/2hQz2XGcOZ0[/video]
3rd movie cutting the traces.
It was an old handyman cnc mill 1.5" diameter ball screws x and y with a stepper driving the feed hand wheel all nema 23 with a centroid controller so I re did it with nema 42 1200oz x and y and a 34 for z with a quill drive - a machmotion clone ( I built ) enclosure and a storage cabinet for the electronics - It has a NEW straddle table splash guard and hard plumbing to a little giant pump - mach3 with a modified screen set I did - mastercam with tool change post processor so I can use tool change location in mach3
will upload more pics
Here is a (short) clip of my machine cutting the backspring for a pocket knife I am working on. Machine is a converted 9x42 import knee mill. Servo's and timing belts with stock screws on X/Y. Ball screw drive on quill for the Z axis. WARNING: the volume is a little high, I have the air blast going.
