- Dec 7, 2018
- 653
Special thank you to Tony who helped diagnose my PM950 problem with me. I have had the mill since January and have used sporadically.
I am modifying one of my cameras L bracket to accommodate my WIFI transmitter. I am making a couple of bracket extensions but when I went to change tooling and restart the mill, it turned on but didn’t go into a higher speed.
I called PM and Tony helped me over the phone. After working through the issues he sent me a new high speed switch that mounts at the top of the motor where the switch is activated by some spring loaded weights that lower down on the contact and once connection is made the motor kicks into high speed.
Thanks Tony and PM.
Thanks Tony and PM.
