Understanding that the Atlas 618 is a small lathe, almost a toy even, I'm wondering if my OEM legs and the motor mount are adding to the vibration and if there's anything I can do that would tighten the lathe up. The reason I think the legs are part of the problem is that the footprint is not very big, and even though the lathe is bolted to the concrete floor of my garage you can only do so much downward.
Then there's the way that the motor is mounted, which I assume is the way these came from Atlas? I'm very new to machining and until I got this lathe I had never turned anything on any lathe whatsoever. I know that pictures are not enough to diagnose the problem but I am suspicious that the motor arrangement is part of the problem and the lack of base width is keeping the lathe from being more stable even though it's bolted down. Thoughts?
