I don't own a Chinese or Taiwanese lathe but I sort of have an opinion about buying lathes in general.
You haven't told us what you intend to do with the lathe so recommending which lathe to get is difficult. The lathe has to be able to handle what you want to do with it. If you have not defined this clearly for yourself then now is a good time to do that.
The size of the lathe is not just about how large a work piece it can handle. Most hobby class lathes below 12" do not have many important features that a good engine lathe needs. You need to be clear on what features are important to you and make sure the lathe you get has them because you cannot upgrade or mod the lathe later on. If you are not clear on which features matter, or why they matter, then ask here until you are clear. Most new lathe buyers do not ask, sad to say.
Beware of shopping purely by looking at spec sheets and comparing features and prices. Quality of construction does not show up on these spec sheets. Taiwan-made machines are typically made to a higher quality standard vs Chinese machines and while it costs more, the general consensus is that it is worth buying the better quality Taiwan machine.
So, once you define your needs and learn enough about lathes to know which features matter, find the lathe or lathes you want to consider and then define your budget. If the lathe you want is beyond your current budget then I suggest you wait until you CAN afford it rather than settling for a lesser machine.
Keep in mind that the basic machine is just part of the cost. It will cost you as much or more than the lathe costs to tool it up and buy the other tools you need to machine stuff. Whenever I see someone lay down a budget ceiling for a lathe I wonder if they are actually aware of the true costs besides the machine; most are not.
Finally, buy your lathe from a good supplier. PM has an excellent reputation for support after the sale that has been proven over the years to be a real thing and they are the outfit I would go to if I were shopping for a new lathe. If you call Matt, I bet he could tell you exactly what the differences are between the Chinese and Taiwanese models in the same swing class.
Purchasing a lathe is not a small decision. Do it with your eyes wide open and be as well informed as you possibly can.
