- Jul 16, 2013
- 43
Good day
It has been a while since I posted something but I finally had some time to spend in the shop.
We have a shop down here that sell used as well new shop tools and from time to time , if you are lucky and at the right time there , you can pick up some gems.
Couple of weeks ago it was one of those times. I picked up a set of thickness gauges for a steal - converted it worked something like $ 55.00.
Now that I have them I had to make a Sidebar.
I didn't have much of material and didn't want to spend money on new material so I salvaged some out of the good old box...
That been said I was constrained by what I had and as a result could not make the perfect length bar but from what I could get from the net was that as long as the top surface is parallel to the round bar and you know the distance between centers of the bars you should be ok.
Dimensions are 90 mm between centers and the run out over the total length is about 0.02 mm. I did the parallel cutting on my Alba Shaper after all was assembled.
Best Regards
Paul
Best Regards
Paul
