- Jan 22, 2014
- 578
As I wind down on one project (Super Bowl Trophy), I always find myself thinking about the next one. I was browsing the web a few weeks ago and found something very interesting that I decided to make. The major components are many hexagons and pentagons that would be around 5/8". They are like window frames with the shape not only on the OD but also the ID. The OD is easy to make, but the ID is the problem. I searched for pre-shaped tubing to no avail and contacted several aluminum extruders, but the cost/quantities were out of the question. So I figured that the only practical way to do it is with a broach.
I looked into purchasing store bought, straight broaches but they were out of the question at $220 for the hexagon, and one of the major suppliers wanted $799 for a custom-made pentagon broach! I could buy a rotary broach set-up but it's too expensive. I could also make one, but it's really not the proper tool for this project because of the limited depth and the quantity I have to make. So I studied my 21st Edition Machinery's Handbook and decided to attempt to make my own broaches from scratch. I'll be machining the window pieces in aluminum so it won't be like cutting steel.
I started with the hexagon by turning a series of incremental sizes in a .625" piece of cold rolled steel bar stock, increasing the depth of cut by .010" per cutter with a .500" pitch. I then mounted it in the rotary table and cut the land width and a clearance angle of 3 degrees. I returned to the lathe to cut a radius in the gullet. I did some fine tuning on the rake angle and then heat treated it. I was a bit anxious when making the first cut but it went through the aluminum like butter producing a very nice hexagon hole. NOTE: The pic is not the finished broach, I cut a lot more clearance for chips in front of the cutters but failed to get a pic at this time.
With the success of the hexagon broach behind me now, I began making the pentagon broach. I included a few extra cutters because the the cuts will be larger with a pentagon shape. After successfully producing a test piece I'm now ready to move on to the the real thing.
Stay tuned.
Rick
Stay tuned.
Rick
