- May 7, 2020
- 267
We have a heavy (6 ton) gantry crane in the shop. Did I mention heavy? It's height adjustable with telescoping uprights. But actually raising it without another crane is an ordeal (imagine a car jack on a ladder and the crane rolling underneath). And we need to lower it all the way to roll it out of the garage to unload outsize tall stuff.
We settled on building an onboard lifting solution. Figured it was a good opportunity to use the new rotary table for the first time in anger.
A little calibration and measuring.
Making a support bracket for the jack.
Like the way that turned out. Two flute HSS seems to work really well for slotting (something I hadn't done much of).
Welding up the frame with upper and lower support brackets attached. You can see where that radius went. Glad my kid loves to weld. We also milled that lower support including a bevel to make it fit the jack. Fun with a facemill.
Doing a little test fitting.
So this is the idea. We'll have a jack on each side. We get over 19" of lift so that allows us to raise the jack three 6" spaced holes in one go (the limit in the garage). And we can secure the uprights, attach some still to be made lifting brackets, and go up to 12' total. That will let us unload tall stuff off the trailer outside the garage.
Some finish work taking off corners, wire wheel and we'll be ready for paint to match the crane. Fun little project that will make our crane a lot more flexible.
