- Feb 17, 2015
- 8
I just picked up a small lathe with a rocker style tool post. I think it's designed for a 3/8 by 7/8 tool holders, of which I have zero.
I can see that I can buy them on Ebay or whatever, but I do have some 3/8 flat steel, and the ability to cut it more or less square and flat. And the whole point of owning machinery is to use it to do and make. So buying is out of the question.
Cutting the 3/8 steel into a shank that the tool post can hold is no problem. But drilling/broaching a square hole to receive the tool bit is probably beyond where I'm at.
However, I do have a metal-cutting skilsaw that I think I can use like a fly cutter to mill a slot. So I'm thinking that cut some 3/8 plate to the general shape of a tool holder and then bend a "head" on it "x" degrees to the left or right. Then I'll cut/mill a 1/4 slot in the outer cheek of the head. Then I'll drill and tap a hole in the cheek so that I can clamp a plate against the toolbit and I'm in business.
So for "standard" left/right/straight tool holders, what angles (both left-right and up-down) should the bit be in relation to the shank of the holder itself? Are there any standards or drawings out there?
Any other advice before I charge down this path?
Thanks in advance,
Bob
Thanks in advance,
Bob
