Shim Stock Punch Set alternative
yukon_rose
Jan 9, 2020
81
I have this shim stock punch set:
which works very nicely. But several times now I needed to punch a hole that is further from the edge of the material than this set allows.
Do you know of a set (similar in design) that has a larger capacity?
Gary
It looks like all the punch sets that work like yours (punch guide and die bolted together, separate loose punches) have pretty much the same depth problem. Whitney-style punches, such as
are limited by the throat depth of about 1 3/4" and maximum hole size of something around 5/16"
Larger punches of this type
have deeper throats (~3 1/4") and punch diameters up to 7/16".
For larger holes, I'd suggest starting with whichever one of these you can get, then increasing the hole diameter with a step drill.
