- May 3, 2020
- 189
I've had this machine for awhile now as a refurb project, and found the spindle bearings are toast. There was no oil in the reservoirs and a nice pile of metal shavings behind the sight glasses. The part numbers are 30212 and 30210. The ones I pulled out of it are standard precision tapered roller bearings. The replacements that Grizzly sells also appear to be standard precision.
My question is if it's worth pursuing higher precision? Perhaps ISO P5. The whole lathe isn't a high class precision machine in the first place, and has some way wear, so I can't see anything more precise than P5 being worth it. I was also looking at SKF Explorer bearings, which I believe are all P6 rated. It seems in general tapered roller bearings don't tend to come in precision ratings.
I'm not trying to split tenths with this machine, and honestly it may run perfectly accurately with standard precision bearings. I've just never had it operating so have no frame of reference for it. Any thoughts?
