- May 3, 2020
- 103
Does anyone know what the bull gear pin on these models is supposed to be like? Mine is clearly something that was put together by a previous owner. They must have had the spindle out at some point, because the bolt is too long to be removed inside the headstock. Is it a 1/2-13 socket head cap screw with the head ground down. I would like to replace it if possible as it's a pain to use. I've seen references to a twist to lock style pin on these as well as some kind of thumb screw, but it seems like these parts are no longer available from Grizzly etc. for the style of lathe most similar to my machine. When the bolt is fully engaged there is around 1/8" of play on the cone pulley, so it's a slightly larger hole, maybe around 5/8" or so. I could be completely wrong and this could be all original, it just does not look quite right to me.
I was considering using a twist to lock style plunger such as this, but I am concerned about the amount of play the pulley will have with the pin engaged due to how large the cone pulley hole is. Is this an issue I need to worry about or would it be fine?
