- Feb 2, 2017
- 1,236
My new-to-me mill needs tooling. I've got some basic end mills coming (Chinese HSS) to learn on, and local benefactors will set me up with a fly cutter and more mills.
I think I need (want) something beyond a fly cutter to remove material from the top surface. I also need (want) a good boring head. I'd planned on picking up a used Sandvik or equivalent shell mill and a Criterion boring head, but when I started looking at Ebay the choices were overwhelming. Then I came across Wohlhaupter boring/facing heads (I'm sure there are others), further confusing me.
I've checked out a few videos and Googled like crazy (including searching here), but all I learned was that shell mills can face and side cut, while face mills are largely for finishing. Is there a primer on more advanced tooling that talks about pros/cons of shapes, number of inserts, shape of insert (square, hex, round, triangle)?
Thanks,
Evan
Thanks,
Evan
