- Feb 15, 2015
- 27
Okay guys. I took the chuck off of my lathe today and was a bit confused by what I saw. For some reason, I just assumed the chuck screwed onto a threaded spindle. Instead, I found what appeared to be a tapered spindle and a loose collar with threads that pulled the chuck up onto the taper.
Does that threaded collar come off? I could not see any way to remove it. Wouldn't it bang around if I had a collet in the spindle hole? Or maybe I still would have some sort of plate attached to it?
On another note, I have the handwheel collet thing that goes through the headstock. However, I seem to be missing some type of sleeve to put in the spindle hole. Does anyone happen to have an extra laying around?
