Hi everyone,
I'm restoring (read: giving a good clean, de-rust, paint and lube) to my recently purchased Sheldon lathe (EXL-56B).
The lathe is in fine working order, but neglected for a while. So I've found the user manual and read a couple of forums + youtube video's in order to dismantle the lathe. The only thing I'm not completely confident about is removing the lead screw. Its screwed on and hold in place by a tapered pin (if I'm correct), but my previous attempts of removing it are not successful and I don't want to ruin any brass bearings or worse.
The main reason why I need to remove the lead screw is because the apron looks horrible + its easier to clean and paint the main body.
Steps until now. Finding the right side of de pin and jamming on it with a light hammer in combination with an old center point. I then grinded one side of the tapered pin to make sure nothing is preventing it to move.. but no luck.
What would your advice be? And how hard can I hit such a pin without damaging?
Thanks in advance, Paul
