Attempting to do some work on this lathe yesterday, discloses that the compound ways have a rather large amount of play.
Investigating to see if the gibs, which appear to be tapered, could be snugged up found a very limited range of push pull available. Perhaps an eighth of an inch total.
disassembling the adjuster screws I found what appear to be home made gib pushers, with one of them having no projection of the finger to push the end of the gib beyond the position of the screw is tight against the pusher which is bottomed in the hole. And it appears that some of the casting has been broken away, and that the gib itself is at least 1/2" short over all.
So, question is: are these three parts available, or should I try to go ahead and use it since in the long run, it will be removed as I CNC this lathe. CNC can program moves that render the compound into a tool holder platform that wiggles when you don't want it to, its motion capabilities are not needed. I have a big block of cast iron to make its bolt on replacement at some point in the future after I get the motors and new ball screws installed, and can actually run it with LinuxCNC.
