I would like to know how to sharpen an end mill. In searching the internet I found information on several types of special machines made for that purpose. As luck would have it,the cost of these devices is out of reach for most of us.
However there is a a fixture available for under $100.00 that is said is able to do the job. There is no information on the what and how to use this device. Studying the photo I assume it is held in a vise,the bottom seems to be machined at two different angles. I assume one half of the bottom of this fixture is machined to grind one angle and that the other half is machined for the second angle and whatever angle you grind on the end mill the corresponding angle of the fixture is laid flat on the bottom of the vise. This brings up an important question ,what are the primary & secondary angles?
There is a collar at the top that apparently holds a 5C collet(This holds the end mill)which would rotate to accomodate the amount of flutes in the end mill. There is the suggestion that the fixture was designed to be used with a surface grinder.
I don't have a surface grinder??? I have a vertical milling machine,is there some way to use it?
Is anyone familar with this tool or have any ideas,comments to achieve what I would like to do,I would greatly appreciate
any feedback
John
any feedback
John
