Sharp Milling Machine Help
bobby light
May 31, 2014
44
Have been trying to find a decent Bridgeport J model for quite some time now. Today I ended up with a Sharp-LC HMV Milling Machine. So far it appears to be a clone of the Variable Speed Bridgeport. Machine has minimal backlash, and came with X axis Servo 150 power feed. Also came with an acuright III DRO
I believe it has an R8 spindle taper, but when I looked inside the spindle taper I don't see the little key way for the the collets to slide into. Is that correct? From all my research I don't believe Sharp HMV mills were made with a different spindle.
Last I was missing the draw bar, but other then that the machine is complete. Can I purchase a draw bar from enco and if so what's the best way to determine size?
Give me a few and I will get some pics of the machine. It's still loaded on the trailer. Not looking forward to moving it.
The head was swiveled upside down for transport.
I flipped the photo :)
Re: Sharp HMV Milling Machine Help
Yes, the Sharp mills (and nearly all knee-mills now) take R8 shank tooling and collets. A drawbar would be a good project if you have a lathe. I believe the R8 shank collets and tooling is 7/16"-20.
Yes I have a few lathes :)
SB 13, SB 9 and a SB Heavy 10
So why is there no key way inside the spindle taper for the collet to align with and slide in?
- - - Updated - - -
Id like to get the machine running asap
Figure this is what I need?
http://www.use-enco.com/CGI/INSRIT?PARTPG=INSRAR2&PMAKA=209-9016&PMPXNO=947840
They key's break off. Not really a problem. Our sharps at school are more or less identical to the bridgeports we have. They have r8
I prefer it without the key way in there actually.lol I wouldn't worry about it. Run it....
Sent from my SPH-L710 using Tapatalk
Thanks for quick replies. It was more of an impulse buy, which I don't like to do when it comes to machinery. For the price it was worth getting this nice machine that will need a little elbow grease to become operational, vs a worn out J head Bridgeport which people want an arm and leg for.
Already have a rotary phase convertor for it, just need to her her moved into the garage. Now I can sell my clausing 8520.
That table is covered in grease, but doesn't have a single drill or nick in it! Really happy with this machine, even though its an import which goes against all my other US made machinery, but I think this was a better buy vs a J head Bridgeport which would also have cost more money.
I love our sharps. Very nice machines. They are new but you can tell right off they are well built
Hey, seems like I read that when u invert the head like that u need to make sure you re oil the cups good and let the oil get back where it needs to be....
Seems logical to me. I need to add a good amount to all the cups. Any recommendation on oils to be used for this machine?
