- May 7, 2014
- 776
Hi Folks. Looking to reduce my cost and simplify a design. Currently I run a 12mm shoulder bolt thru a 12mm linear bearing embedded in aluminum. In short, the shoulder-bolt simply rides and slides inside the 1" long linear bearing.
Someone we all know and trust here suggested I could try to eliminate the linear bearing assy. To do this, I should try to setup a 12-mm precision reamed hole. Then use the .002 under shoulder bolt directly into the reamed hole.
I have wanted to learn how to do a precision hole for a time now so this is a perfect 1st ream project. I'll dig and read a bit, but as for a CNC process and order of ops what size holes do I drill first? Do I need the 11 or 11.5mm reamer and set the process up to 12mm
thanks everyone.
J
thanks everyone.
J
