- Dec 31, 2010
- 937
The adjustable angle plate I have uses Tee nuts unlike any I have for other machines in the shop so am going to make some using the shaper, The stock is mystry metal with a torch cut on one long side which has become the test area for my cutter sharpening efforts. I have started with a new piece of 1/4" x 1/2"x2" HSS by grinding a 901 point with relief on both sides for bi-directional cutting. It is cutting well @ approximately 0.010" deep and 0.010" wide. Tomorrow the point will become a slight radius and a rake angle included. Somewhere I got the impression the rake should be negative. Any help on this will be appreciated.
Also spent some time trying to cut grooves parallel to the adjustable table face, All things considered a good day.
Enjoy your 4th of July!
Rock Breaker
t
Rock Breaker
t
