Series 1 X And Y Axis Q-release Handle Repair Questions
G
gapi
Forum Guest
Register Today
We have a Series 1 2HP that has quick release handle issues. I pulled the right side handle off and was able to slide the sleeve off and clean it for an improvement . But the holes are worn and it needs top be replaced.
When I removed the left side (in hoped it was better, and to swap them) I could not get it off. Am I missing something, or is it just binding on hard.
Serial number on the side of the machine is 438551287x
Thanks
Can you post a picture? I'm not sure I have seen a system like that.
Well, maybe I explained it wrong. Its for the handles on machines with power feeds so they don't spin and knock you around.
I'm not with the machine now but here is a Y axis photo I have on my phone.
The X-axis is my concern, I cannot get the sleeve off.
My best guess is that is just stuck. Look for any set screws or threads, but if one side came off, I going to say that the other side should be the same.
handle.jpg You need a collapsible handle, they are like a round wheel with a crank that folds in. Then you wont get knocked around. Tim
I fixed Right X and the Y crank handles. The left one is a thrust and crank bushing @$488.88 so we do without.
We also put a rebuilt motor on the Y.
They were pretty worn out. A new one is in center @$103.00 each.
