Do you speak from experience? I never would have thought of it.What ever you do, don't lower the knee all the way down. It could get stuck due to dirty and dry gibs.
That's a problem Richard King pointed out somewhere, make sure they are kept perfectly clean. The absolute bottom of the dovetails are often coated in dried oil and dirt. The bottoms also never see wear. Just like a carriage lock gets tighter toward the tailstock. The knee gib can only be loosened by pulling up on the notch in the top. If it's wedged, the notch will break off!Do you speak from experience? I never would have thought of it.
Absolutely! I do think stripping a mill down is a good exercise for a new user!I would add, maybe someone packed the oil fittings with grease? Very common.
Bridgeports only have a screw on the top.The machine has a one shot oiler and i pulled the line off the knee and confirmed there's oil flow.
I found when lowering the knee it would drop in steps, so now I'm working on adjusting the gib, while manually applying oil as I raise and lower.
The manual says there's a gib screw on the bottom as well as the adjustment screw on the top, but mine has no screw on the bottom, see pic. Note: pic is backwards, this is the left/ gib side
