I am refirbing a Bridgeport Series 1. I have the Ram - head assembly off and have just completed the head reassembly. There is a definite preiodic noise on high speed. Neutral and Low are wisper quiet, there is not issue there. The noise is speed dependent.
I have tried loosening the three clutch cover bolts and twisting the head. That has a definite impact on the noise, but there is no positon where it is gone.
I have tried loosening the three gear cover bolts and twisting the head. That has a definite impact on the noise, but there is no positon where it is gone.
Based on the above the only parts that are in play in high and not in play in neutral and low are the cog gears between upper drive shaft spindle and the gear spindle. As near as I can see everything else is part of the neutral or low speed drive.
Is there an alignmnet tool to insert between them during assembly?
What am I missing?
Thanks, Dan
BTW it is even impressing in low.
What am I missing?
Thanks, Dan
