Hi
I use a Clarke CL500M lathe to remove the flanges off studs as per the pics below. I do this about a thousand studs at a time. The process of opening the chuck, placing a stud, tightening the chuck, shaving the flange off, opening the chuck again and removing the stud takes me about a minute. Up until now I've been paying for someone else to do it ($2000 this year), but I'd rather do it myself more efficiently.
Is there some kind of semi auto lathe on the market, with some kind of quick load chuck, where the cutter automatically goes back and forth to some presets I can set up beforehand, but at a speed where I can just swap the stud over between strokes without having to tighten and untighten the chuck. If I can get the speed up from one a minute, to say 10 a minute, then it becomes worthwhile for me to invest in something new.
If yes, what would such a device be called? I'm looking for something that can handle up to M10/M12 studs, and maybe with a way to shave the pip off the top of the stud too via a second batch run, once the flange is shaved down.
Thanks in advance!
Dibbs
Thanks in advance!
Dibbs
