- May 10, 2022
- 5
Hello,
Yes, another Seig mill conversion thread... However I haven't seen much discussion on the X1 within quite a few years span, and those threads never seemed to come to any resolution. To make matters worse, all of the referenced material (Hossmachine, CNCfusion, Yahoo groups) are dead.
I've basically been given a Seig X1 (HF Model), with a shredded transmission. Since I already have a nice manual mill, i'm planning on converting this to belt drive and making it a CNC. I've done some RC and 3d printing projects in the past, but I have no idea where to start with CNC beyond the basic concept of it.
I'd like to build something reasonably functional for the lowest initial cost, possibly upgrading as I learn, so i'll be skipping a ballscrew upgrade for now, and just dealing with backlash adjustments in software. I'm not sure the design of the belt drive yet. I haven't decided if it's really important to keep the weight of the motor centered directly over the head or not. I'm probably going to fabricate a plate and turn some pulleys but i'm not sure what size I need for the best speed using small tools taking repeated light cuts on aluminum and steel.
Anyway, to sum up, here's my planned build so far:
Base Mill: HF Seig X1 (I'm planning to counterweight the head + modifications)
Motors, Control Board, Drivers, PSU: https://www.amazon.com/gp/product/B09MRQKF43/ref=ox_sc_act_title_2?smid=A3E9T3KQ1YPBBY&th=1
Motor Mounting: https://www.thingiverse.com/thing:873408
Computer: One of my junk computers I have lying around
Software: Probably going to look into CNC Linux.
Belt Drive: I need help determining pulley size, but will fabricate as needed.
Does that electronics package seem sufficient? Am I missing something critical that's necessary to function? How do I determine a good pulley size?
