- Jun 7, 2021
- 2
Hey folks,
I just joined to get some expert advice on a problem that I am having.
Over memorial day weekend, I reacquired my dad's old lathe. He bought it used sometime before 1996 and I got it when he passed away. It sat in my shed/shop for a few years, then sat in my step dad's shed for a few years, then sat in my brother-in-law's shop for a few more years. It was developing a bit of surface rust on the ways, the cross-feed and the chuck. I have the ways mostly cleaned up but I'm still working on the rest of it.
The problem I'm having is the the direct drive coupling is in the back gear position and will not move in or out. it does spin freely most of the time but binds on occasion. I think the binding is due to the woodruff key being loose and floating around back there and getting caught up on something at times. I know it's there because I can see it shining away at the bottom of the pulley. The outer retaining is missing, as well.
Looking at the exploded view, (I found a manual online that I am referencing), it seems that with the outer retaining clip gone, the coupler should come off the spindle and with the woodruff key loose, the coupler should go in, even without being exactly aligned. Neither assumption is true , though. After some studying and finger nail chewing and WD-40 spraying, I decided to whack the coupling with a rubber hammer, thinking that maybe the retaining ball and spring were stuck and that could break them loose. No luck with that. I also tried getting a couple small screw driver blades in between the pulley and coupler to see if I could pry it out. No luck there, either.
I'm sure this has been going on for some time as the coupler looks like it got intimate with a pair a channel locks more than once. I will try to attach some picture so you all can see what I am seeing.
I would really like to get this up and running since I have a project that is just a little too big for my Sherline lathe to handle well.
Thanks in advance for any and all help and advice you can provide.
Bill
Bill
