[How-To] Scriber material
DavidR8
Staff member
H-M Platinum Supporter
Oct 16, 2019
6,876
I'd like to make a decent scriber since I'm always looking for something when doing layout. I recently came into some brass rod for the body but I'm at a loss of what to use for the scribe part.
I was thinking of using a 3/32" TIG electrode as they seem to be very hard, albeit perhaps a bit brittle.
Any suggestions on good material to use?
David...I use an old Starrett watchmaker's screwdriver....sharpened to a tip. When it gets a little dull, it takes a couple of seconds to sharpen on a grinding wheel, sanding belt or #220 grit paper on a block. In your case, the drill approach cited above is a great idea too. I made a scribe with a brass handle and used 0.125" diameter O-1 tool steel...hardening and tempering the tip was easy to do: heat to cherry red (or so) with a propane torch and quench in vegetable or motor oil. Clean the oxide off with #220 grit paper and then heat until it turns a straw color.
I made one from a lead drafting pencil holder and use a sharpened tig Tungsten rod, works for me
Great idea!
Excellent feedback gents!
Starrett also sells hardened steel and carbide replacement scribe tips on Amazon. I own scribes with both of these kinds of tips and they work really well but the carbide one stays sharp longer.
