B
BRIAN
Forum Guest
Register Today
Heving just lately converted my 7 x to belt drive and not yet got the motor to reverse. I was forced into using the dial
for the first time. to cut a 8mm thread with the metric lead screw already in I only need to put the correct dial on ( the one with 12 divisions ) and i am away Thinks I ,Just use No 1 ( to mutch in a rush to find the chart??? )
First pass OK second pass Oh me Gawd.! wiped out all my good work.
So look at the chart FOOL.
Now the metric dial that came with the lathe has 16 teeth
The chart says use a dial with 15 teeth for this thread. also there is a dial with 14 teeth for other threads
Look up the spares Only 16 teeth dials available for this lathe??
SO after a lot of extra work I made a cutter and then made the gear. and now i can cut 8mm threads OK
But i wonder? I have seen other threads from people having thread cutting problems .Can this be one of the causes.
Food for thought??
Regards BRIAN.
Food for thought??
Regards BRIAN.
