- Jan 4, 2012
- 108
(why is ENTER or RETURN not working on this site ????)
I'm working on getting this monster going for my little
workshop - look it here: http://kelds.weebly.com/skruekompressor.html (you can translate by choosing language to the right under the menu line !)
I plan to mount it with a small tank - about 50 liters - and
I have tried it for testing the configuration !
When it starts it fills up the tank very fast and then stops - it's OK - I beleave.
When I starts to use some of the air, a sort of "humming" is comming up and
the motor run very slowly, while filling up then tank again OR keep up with my
using/spending of air.
Is that "normal" behavior or way of using such a compressor ?
Can it be damaged in any way because I'm NOT using all it's capacity ?
