hi everyone. Scraping is going along great and ive been looking for more things to practice on. Im in the market for a new lathe so i figured the cross slide and compound of my 12x36 atlas was a good candidate. They are horribly roughly milled. I have some questions though.
For the compound the slide is longer than the base. Ive got the flat side of the top part coming in nicely. Since the top part is longer its easy to just use it as a master for the lower part of the compound.
On the cross slide the ways are longer than the upper part so i cant just scrape the top and use it as a master. In this case do i just remove the carriage and scrape the ways in to flat independently and use my dti and surface plate to maintain the two ways in the same plane and then use the carriage as a master for the cross slide? Opposite master child relationship tha. I used with the compound.
Thoughts?
Thoughts?
