Thanks for your input guys.
Yes, I have a double-ended Baldor clone from HF (I scraped the table flat). I'm using a 360-grit Accu-Finish wheel which definitely works on the carbide Biax blades. I had to make larger holes in the wheel and re-tap the threads on the grinder plate to make it fit though.
I was just curious how much much a difference it would make to sharpen on the slow speed Accu-Finish (or Calamar) at slower speed and finer grit. I suppose it's the difference between grinding and honing the edge. I just don't have a good sense of how much of a real-world difference it will make when it comes to scraping. Maybe I'll just get one and try it out.
