This lathe deserves its own thread, even though Grizzly may be discontinuing it.
Note: Take everything I say with a grain of salt. I am a self-taught hobby machinist, with most of my experience is on a MicroMark 7x16 mini-lathe. My goals in upgrading were a larger work envelope, more low-speed performance especially for threading, and general improved performance. Living on a hill a city means I have limited space and weight capacity for tools.
The SB1007 is almost an exact copy of the Emco Super 11. You can read all about the original on www.lathes.co.uk - it was a high quality machine.
Unboxing was pretty straightforward. The lathe came with minimal accessories - a 3-jaw chuck w/ reversible jaws, an outboard spindle spider, an MT5 to MT3 adapter for the spindle, a 4-way toolpost, and a variety of tools. The spindle is D1-4 w/ MT5 taper, the tailstock is MT3, the lead screw is 8 TPI. Cross slide and compound slide lead screws are metric - 2mm and 1.25 mm respectively. Initial spindle break-in and test cuts went fine.
Stay tuned for more.
