Sb Heavy 10 Parts And Drawings Diagrams
HMF
Site Founder
Administrator
Sep 22, 2010
7,222
Parts and diagrams for the H-10 -_How_to_Wire_a_VFD.gif -+Lube_Wall_Chart.GIF +lubrication_2-med (1).jpg +lubrication_2-med.jpg +oil flow 1 (1).jpg +oil flow 1.jpg +oil return1 (1).jpg +oil return1.jpg +oilpassages2 (1).jpg +oilpassages2.jpg -10L Toolroom Lathe Specifications.jpg FullSizeRender.jpg FullSizeRender-2.jpg -Gearbox_Wide_947C.jpg head.JPG -IMG.jpg -Level_Lube_Wall_Chart.GIF -Leveling Lathe_Instructions (1).GIF -Leveling Lathe_Instructions.GIF Lube Oil Specs 1967 (1).jpg Lube Oil Specs 1967.jpg -mic_stop.jpg MVC-804S.JPG MVC-805S.JPG -P1010479.JPG -P1010480.JPG Ps02d.jpg Ps03d.jpg Ps04d.jpg Ps05d.jpg Ps06d.jpg Ps07d.jpg ps08c.jpg ps09d.jpg ps10.jpg ps11.jpg ps12.jpg ps13.jpg ps14.jpg ps15.jpg ps16.jpg RestoredHalfNuts_1.jpg RestoredHalfNuts_2.jpg sb_ad_10k_1958.jpg sb_ad_collet_0858.jpg sb_ad_lathes_1957.jpg sb_ad_mill_0857.jpg -SB_Label.gif SBL Taper Inst-6.jpg Tail.JPG -Wiring_Diagram_3_Phase_Motor.jpg
  • -Accessories- 10 in 1 Tool Block_946A.pdf
  • -Accessories- Double_Tool_Cross_Slide_938B.pdf
  • -Accessories- Four Position Carriage Stop_940A.pdf
  • -Accessories- Micrometer_Carriage_Stop_933A.pdf
  • -Accessories- Swivel Machine Vice_964B_S3_vise.pdf
  • -Accessories- Handlever Tailstock_989_S3.pdf
  • -Accessories- Handwheel_Collet_Attachment_923E.pdf
  • -Accessories List- 1949_Bltn_No.277.pdf
  • -Accessories List- 1957_mailer_09-07.pdf
  • -Accessories- Mica Attachment_989_S3.pdf
  • -Accessories- Regular_Steady_Rest_942A.pdf
  • -Accessories- Square Turret Tool Block_944A.pdf
  • -Accessories- Tool Reamer_990 (1).pdf
  • -Accessories- Tool Reamer_990.pdf
  • -Accessories-Handlever Turret Tailstock_966A_pdf (1).pdf
  • -Accessories-Handlever Turret Tailstock_966A_pdf.pdf
  • -Accessories-Handlever_Collet_Attachment_924E (1).pdf
  • -Accessories-Handlever_Collet_Attachment_924E.pdf
  • -Accessories-Handlever_Turret_937C (1).pdf
  • -Accessories-Handlever_Turret_937C.pdf
  • -Accessories-Indexing Centers_965A_S3_Inx_centers (1).pdf
  • -Accessories-Indexing Centers_965A_S3_Inx_centers.pdf
  • -Accessories-Indexing_Table_956A.pdf
  • -Accessories-Milling_Attachment_939C.pdf
  • -Accessories-Regular_Follower_Rest_941A.pdf
  • -Accessories-Taper_Attachment_922D.pdf
  • -Accessories-Taper_Attachment_Crossfeed_Screws_978A.pdf
  • -Accessories-Telescoping_Jaw_Steady_Rest_943A.pdf
  • -_Calendar 2015.pdf
  • +Lubrication_chart_6503 (1).pdf
  • +Lubrication_chart_6503.pdf
  • +SBL_Oiling_Guide (1).pdf
  • +Where Do I Get the Felts For a Heavy 10.pdf
  • +Where to Buy Lubricants for Your Lathe (1).pdf
  • 8'' JR 405 Backplate.pdf
  • 3037-Countershaft.pdf
  • -12770084-Machinist-Course-Milling-Machine-Operations.pdf
  • A Large Dal Conversion on Workshop Model C_Model 405 lathe1.pdf
  • A large Dial Roller Bearing Compound Screw for SB Workshop.pdf
  • -Alligator_Lacing (1).pdf
  • -Alligator_Lacing.pdf
  • -American wire gauge (1).pdf
  • -American wire gauge.pdf
  • an ER-40 Collet chuck.pdf
  • -Apron_11-16_and_1_inch_910D.pdf
  • -Apron_910c.pdf
  • Assem_54[1].pdf
  • Assem47[1].pdf
  • BallTurner.pdf
  • -Belt_Splicing_Instructions_Bulletin_No_5125 (1).pdf
  • -Belt_Splicing_Instructions_Bulletin_No_5125.pdf
  • -Belt_Splicing_Instructions-Bulletin_No_600 (1).pdf
  • -Belt_Splicing_Instructions-Bulletin_No_600.pdf
  • -BULLETIN_645B.pdf
  • -cat_bl_29b.pdf
  • -catno.pdf
  • -CE3458 Parts Manual.pdf
  • -Collet Hand Lever Installation.pdf
  • -Commercially Available Hardware Items - Form 1178 b&W.pdf
  • -Commercially_Available_Hardware_Items_Form_1178.pdf
  • -Compound_Rest_Top_948C.pdf
  • -CONVERTING A SOUTH BEND HEAVY 10 SMALL DIAL CROSS (1).pdf
  • CONVERTING A SOUTH BEND HEAVY 10 SMALL DIAL CROSS.pdf
  • -CONVERTING A SOUTH BEND HEAVY 10 SMALL DIAL CROSS.pdf
  • -Cross-Slide Stop.pdf
  • -Cutting_27_TPI_968.pdf
  • -Description of Three-Phase Electric.pdf
  • -disconnect.pdf
  • -Double_Gearbox_914C.pdf
  • drawer_materiales_47[1].pdf
  • ER-40 Collet Chuck 9-in Workshop.pdf
  • -ER-40 Collet Chuck for the Heavy 10.pdf
  • -EV_Installation (1).pdf
  • -EV_Installation.pdf
  • -First-Year-Lathe-Book.SouthBend.pdf
  • -Gear_Box_Single_915B.pdf
  • -Gearbox_Single_916A.pdf
  • -Headstock_908c.pdf
  • -Headstock_909E.pdf
  • -Heavy_10_Lube_Chart.pdf
  • -Jacobs Rubber-Flex Collet Chuck.pdf
  • -Knurling-Manual.pdf
  • -Later_10L_Cabinet_Model.pdf
  • -Lathe Belt Sizes.pdf
  • -LATHE PUSHBUTTONS.pdf
  • -Lathe Tooling Dimensions_7324.pdf
  • -Lathe-Tutorial.pdf
  • -Long_ Taper_Key_and_D1_Cam_Lock_Headstock_Spindles_961A.pdf
  • Lube OILING_THE_LATHE_H2 (1).pdf
  • Lube OILING_THE_LATHE_H2.pdf
  • -Lubrication_Chart_6008.pdf
  • -Lubrication_chart_6503.pdf
  • -Machining the QCTP securing nut on a lathe.pdf
  • Marks South Bend thread dial.pdf
  • materiales_54[1].pdf
  • MiniLatheUsersGuide.pdf
  • MiniMillUsersGuide.pdf
  • -Motor_Cabinet_Base_Floor_Type_918B.pdf
  • -My Heavy 10 Painting-Slight Restore (1).pdf
  • -My Heavy 10 Painting-Slight Restore.pdf
  • -My Third Hand.pdf
  • -Painting my heavy 10.pdf
  • Pre-threaded SB 8Jr. & 405 Back Plate Finish Detail.PDF
  • ps1148.txt
  • -Rebuilding a South Bend Heavy 10 Tailstock _2_ (1).pdf
  • -Rebuilding a South Bend Heavy 10 Tailstock _2_.pdf
  • -Reference Information from ShopSwarf.pdf
  • -Reminder to All Southbend 10L Members.txt
  • -remove-taper-feed-screw-10L-16inch.pdf
  • RestoredHalfNuts.txt
  • -Rigging-Handbook.fm5_125.pdf
  • -Saddle Lock Heavy 10.pdf
  • -Saddle_911J.pdf
  • SB cross slide nut pins (1).pdf
  • SB cross slide nut pins.pdf
  • -SB_Catalog_Form 8305-1-87.zip
  • -SB_Machine_Shop_Course_1930_Bltn_No.55.pdf
  • -SB_OILING_THE_LATHE_H2.pdf
  • -SB_Parts-Pt7.pdf
  • -SBL_Headstock_Bearing_Adjustment (1).pdf
  • -SBL_Headstock_Bearing_Adjustment.pdf
  • -SBL_Oiling_Guide (1).pdf
  • -SBL_Oiling_Guide.pdf
  • -ScotchBrite Grit Chart.pdf
  • -serialno.pdf
  • South Bend 9 conversion C to A (1).pdf
  • South Bend 9 conversion C to A.pdf
  • -South Bend 10 inch Precision Lathe Specifications.pdf
  • -South Bend Lathe Catalog Numbers.pdf
  • -South Bend Links.pdf
  • -South Bend Newbie's Guide to Rebuilding a lathe..pdf
  • -South Bend Turret Lathe.pdf
  • -Southbend B-M Paint Color Formula (1).pdf
  • -Southbend B-M Paint Color Formula.pdf
  • -Tailstock_912E.pdf
  • -thread_dial_10-16.pdf
  • -Thread_Dial_Chart.pdf
  • -ThreadTables.pdf
  • -Tool Post Alignment Tool by Frank Ford.pdf
  • -tool_post_mill.pdf
  • -Underneath_Drive_917C.pdf
  • -Use of Accessories Inside the South Bend Head Stock.pdf
  • User-Guide (1).pdf
  • -VFD_Conversion.pdf
  • -Where Do I Get the Felts For a Heavy 10.pdf
  • -Where to Buy Lubricants for Your Lathe.pdf
  • -Wiring_Diagram_GE_Drum_Switch (1).pdf
  • -Wiring_Diagram_GE_Drum_Switch.pdf
