I sometimes sand stainless steel. I use https://www.onlineindustrialsupply.com/3weblnoho.html because the 3" size work for the small pieces and concave surfaces I work on. I like this line because you can go from very coarse (60 grit) all the way to very fine (2500) at which point I switch over to polishes.
BUT, these sheets wear out on steel very fast. Maybe 10 seconds on my orbital sander ( https://www.griotsgarage.com/product/3+inch+random+orbital.do?from=ac )
So I take it 10 seconds at a time, let sander spin down., change sheets, 10 more seconds.
I would love to find 3" hook and loop sanding sheets that range all the way up to 2500 grit that are better suited for stainless steel.
Any suggestions?
Thanks.
-Bill
Any suggestions?
Thanks.
-Bill
